Modeling and control of series resonant converter for high voltage applications - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2014
Bilal Amghar
  • Function : Author
  • PersonId : 914080
A-Moumen Darcherif
  • Function : Author
  • PersonId : 932662
Most industrial processes that use electricity as a source of voltage or current, require power circuit for the control of its physical quantities. Power converters are a multi-site privileged in the control of high power systems.In this article we show that the series resonant DC/DC converter, which is a hybrid system. The SRC achieves an output DC voltage equal to n times the input voltage of the converter, the major disadvantage of this type of converter is the the stresses on the power components and Capacitor Charge Time. Furthermore, a control strategy for minimizing the no-load conduction losses is proposed and the transient behavior in case of load steps including output short-circuit is discussed based on digital simulations.
HalinriabCroatie.pdf (1.27 Mo) Télécharger le fichier
Dates and versions
hal-01092213 , version 1 (08-12-2014)
Identifiers
Cite
Bilal Amghar, A-Moumen Darcherif, Jean-Pierre Barbot, Djamel Boukhetala. Modeling and control of series resonant converter for high voltage applications. IEEE Energycon 2014, May 2014, Dubrovnik, France. pp.216 - 221, ⟨10.1109/ENERGYCON.2014.6850431⟩. ⟨hal-01092213⟩
413 View
1493 Download
Share
