Exposure to hycanthone alters chromatin structure around specific gene functions and specific repeats in Schistosoma mansoni. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Genetics Année : 2014
Schistosoma mansoni is a parasitic plathyhelminth responsible for intestinal schistosomiasis (or bilharzia), a disease affecting 67 million people worldwide and causing an important economic burden. The schistosomicides hycanthone, and its later proxy oxamniquine, were widely used for treatments in endemic areas during the twentieth century. Recently, the mechanism of action, as well as the genetic origin of a stably and Mendelian inherited resistance for both drugs was elucidated in two strains. However, several observations suggested early on that alternative mechanisms might exist, by which resistance could be induced for these two drugs in sensitive lines of schistosomes. This induced resistance appeared rapidly, within the first generation, but was metastable (not stably inherited). Epigenetic inheritance could explain such a phenomenon and we therefore re-analyzed the historical data with our current knowledge of epigenetics. In addition, we performed new experiments such as ChIP-seq on hycanthone treated worms. We found distinct chromatin structure changes between sensitive worms and induced resistant worms from the same strain. No specific pathway was discovered, but genes in which chromatin structure modifications were observed are mostly associated with transport and catabolism, which makes sense in the context of the elimination of the drug. Specific differences were observed in the repetitive compartment of the genome. We finally describe what types of experiments are needed to understand the complexity of heritability that can be based on genetic and/or epigenetic mechanisms for drug resistance in schistosomes
Roquis-2014-FrontiersGenet-Exposure.pdf (1.17 Mo) Télécharger le fichier
hal-01112701 , version 1 (07-08-2019)
David Roquis, Julie M. J. Lepesant, Emanuel Villafan, Jérôme Boissier, Cristina Vieira, et al.. Exposure to hycanthone alters chromatin structure around specific gene functions and specific repeats in Schistosoma mansoni.. Frontiers in Genetics, 2014, 5, pp.207. ⟨10.3389/fgene.2014.00207⟩. ⟨hal-01112701⟩
203 Consultations
85 Téléchargements
