Reduced order model in cardiac electrophysiology with approximated Lax pairs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Computational Mathematics Année : 2015
A reduced-order method based on Approximated Lax Pairs (ALP) is applied to the integration of electrophysiology models. These are often high-dimensional parametric equation systems, challenging from a model reduction standpoint. The method is tested on two and three dimensional test-cases, of increasing complexity. The solutions are compared to the ones obtained by a finite element. The reduced-order simulation of pseudo-electrocardiograms based on ALP is proposed in the last part.
ALPep.pdf (2.18 Mo) Télécharger le fichier
hal-01093488 , version 1 (10-12-2014)
hal-01093488 , version 2 (07-12-2015)
Jean-Frédéric Gerbeau, Damiano Lombardi, Elisa Schenone. Reduced order model in cardiac electrophysiology with approximated Lax pairs. Advances in Computational Mathematics, 2015, 41 (5), pp.1103-1130. ⟨10.1007/s10444-014-9393-9⟩. ⟨hal-01093488v2⟩
232 Consultations
198 Téléchargements
