Experimental plug and play quantum coin flipping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nature Communications Année : 2014
Performing complex cryptographic tasks will be an essential element in future quantum communica-tion networks. These tasks are based on a handful of fundamental primitives, such as coin flipping, where two distrustful parties wish to agree on a randomly generated bit. Although it is known that quantum versions of these primitives can offer information-theoretic security advantages with respect to classical protocols, a demonstration of such an advantage in a practical communication scenario has remained elusive. Here, we experimentally implement a quantum coin flipping protocol that performs strictly better than classically possible over a distance suitable for communication over metropolitan area optical networks. The implementation is based on a practical plug&play sys-tem, designed for quantum key distribution. We also show how to combine our protocol with coin flipping protocols that are almost perfectly secure against bounded adversaries, hence enhancing them with a level of information-theoretic security. Our results offer a powerful toolbox for future secure quantum communications.
1306.3368.pdf (616.18 Ko) Télécharger le fichier
hal-01094106 , version 1 (22-12-2014)
Anna Pappa, Paul Jouguet, Thomas Lawson, André Chailloux, Matthieu Legré, et al.. Experimental plug and play quantum coin flipping. Nature Communications, 2014, pp.9. ⟨10.1038/ncomms4717⟩. ⟨hal-01094106⟩
272 Consultations
154 Téléchargements
