Graph-theoretical Bounds on the Entangled Value of Non-local Games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce a novel technique to give bounds to the entangled value of non-local games. The technique is based on a class of graphs used by Cabello, Severini and Winter in 2010. The upper bound uses the famous Lovász theta number and is efficiently computable; the lower one is based on the quantum independence number, which is a quantity used in the study of entanglement-assisted channel capacities and graph homomorphism games.
1404.3640.pdf (414.84 Ko) Télécharger le fichier
hal-01094118 , version 1 (22-12-2014)
André Chailloux, Laura Mančinska, Giannicola Scarpa, Simone Severini. Graph-theoretical Bounds on the Entangled Value of Non-local Games. TQC 2014, May 2014, Singapour, Singapore. ⟨10.4230/LIPIcs.xxx.yyy.p⟩. ⟨hal-01094118⟩
Collections
INRIA INRIA2
60 Consultations
98 Téléchargements
