Introduction to the Calculus of Inductive Constructions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
This paper gives an introduction to the Calculus of Inductive Constructions, the formalism behind the Coq proof assistant. We present the language and the typing rules, starting with the pure functional part and then introducing the inductive declarations. We briefly discuss the properties of this language, both from the theoretical and pragmatic points of view and give examples of applications.
CIC.pdf (353.34 Ko) Télécharger le fichier
hal-01094195 , version 1 (11-12-2014)
  • HAL Id : hal-01094195 , version 1
Christine Paulin-Mohring. Introduction to the Calculus of Inductive Constructions. Bruno Woltzenlogel Paleo; David Delahaye. All about Proofs, Proofs for All, 55, College Publications, 2015, Studies in Logic (Mathematical logic and foundations), 978-1-84890-166-7. ⟨hal-01094195⟩
1058 Consultations
16507 Téléchargements
