Consistency of injective tree patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Claire David
Nadime Francis
Filip Murlak
  • Fonction : Auteur
  • PersonId : 962357
Testing if an incomplete description of an XML document is consistent, that is, if it describes a real document conforming to the imposed schema, amounts to deciding if a given tree pattern can be matched injectively into a tree accepted by a fixed automaton. This problem can be solved in polynomial time for patterns that use the child relation and the sibling order, but do not use the descendant relation. For general patterns the problem is in NP, but no lower bound has been known so far. We show that the problem is NP-complete already for patterns using only child and descendant relations. The source of hardness turns out to be the interplay between these relations: for patterns using only descendant we give a polynomial algorithm. We also show that the algorithm can be adapted to patterns using descendant and following-sibling, but combining descendant and next-sibling leads to intractability.
25.pdf (494.99 Ko) Télécharger le fichier
hal-01094596 , version 1 (12-12-2014)
hal-01094596 , version 2 (08-01-2015)
  • HAL Id : hal-01094596 , version 2
Claire David, Nadime Francis, Filip Murlak. Consistency of injective tree patterns. Foundations of Software Technology and Theoretical Computer Science, Dec 2014, New Dehli, India. ⟨hal-01094596v2⟩
163 Consultations
94 Téléchargements
