New interface
Conference papers
Consistency of injective tree patterns
Claire David 1 Nadime Francis 2 Filip Murlak 3
2 DAHU - Verification in databases
LSV - Laboratoire Spécification et Vérification [Cachan], Inria Saclay - Ile de France
Abstract : Testing if an incomplete description of an XML document is consistent, that is, if it describes a real document conforming to the imposed schema, amounts to deciding if a given tree pattern can be matched injectively into a tree accepted by a fixed automaton. This problem can be solved in polynomial time for patterns that use the child relation and the sibling order, but do not use the descendant relation. For general patterns the problem is in NP, but no lower bound has been known so far. We show that the problem is NP-complete already for patterns using only child and descendant relations. The source of hardness turns out to be the interplay between these relations: for patterns using only descendant we give a polynomial algorithm. We also show that the algorithm can be adapted to patterns using descendant and following-sibling, but combining descendant and next-sibling leads to intractability.
Document type :
Conference papers
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-01094596
Contributor : Nadime Francis Connect in order to contact the contributor
Submitted on : Thursday, January 8, 2015 - 2:04:22 PM
Last modification on : Friday, September 16, 2022 - 2:02:20 PM
Long-term archiving on: : Thursday, April 9, 2015 - 10:36:29 AM
File
25.pdf
Publisher files allowed on an open archive
Identifiers
  • HAL Id : hal-01094596, version 2
Citation
Claire David, Nadime Francis, Filip Murlak. Consistency of injective tree patterns. Foundations of Software Technology and Theoretical Computer Science, Dec 2014, New Dehli, India. ⟨hal-01094596v2⟩
Share
Metrics
Record views
158
Files downloads
91
