Technical report: Multivariate signal analysis by recurrence plots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
This paper investigates methods for analysing dynamics of biological systems characterised by multimodal signals of different dimensionality, such as polysomnography (sleep) signals or population tracking. We study statistical properties of low dimensional representations of multimodal signals, which we want to use as features for detection of intrinsic signal state changes. We assume that distinctive state transition features remain preserved in low dimensional signal representations of dynamical system signals. We first build recurrence plots for well-behaved biological systems (predator-prey model and Lorenz system which models a forward osmosys). Then, we provide recurrence plot analysis for the real dataset (visual stimulation of ferrets) and we show that preliminary statistical analysis of ferret datasets has stable characteristics. This motivates us to further pursue study on sleep signal statistics that we plan to use for sleep stage detection.
tech_report.pdf (10.5 Mo) Télécharger le fichier
hal-01095315 , version 1 (15-12-2014)
  • HAL Id : hal-01095315 , version 1
Tamara Tosic, Axel Hutt. Technical report: Multivariate signal analysis by recurrence plots. [Research Report] INRIA Nancy, Neurosys. 2014. ⟨hal-01095315⟩
186 Consultations
245 Téléchargements
