Long and winding central paths - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
We disprove a continuous analog of the Hirsch conjecture proposed by Deza, Terlaky and Zinchenko, by constructing a family of linear programs with 3r+4 inequalities in dimension 2r+2 where the central path has a total curvature in Ω(2r/r). Our method is to tropicalize the central path in linear programming. The tropical central path is the piecewise-linear limit of the central paths of parameterized families of classical linear programs viewed through logarithmic glasses. We show in particular that the tropical analogue of the analytic center is nothing but the tropical barycenter, i.e., the maximum of a tropical polyhedron. It follows that unlike in the classical case, the tropical central path may lie on the boundary of the tropicalization of the feasible set, and may even coincide with a path of the tropical simplex method. Finally, our counter-example is obtained as a deformation of a family of tropical linear programs introduced by Bezem, Nieuwenhuis and Rodríguez-Carbonell.
hal-01096452 , version 1 (17-12-2014)
Xavier Allamigeon, Pascal Benchimol, Stéphane Gaubert, Michael Joswig. Long and winding central paths. 2014. ⟨hal-01096452⟩
228 Consultations
0 Téléchargements
