Periodic forcing of stabilized E-I networks: Nonlinear resonance curves and dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
Inhibition stabilized networks (ISNs) are neural architectures with strong positive feedback among pyramidal neurons balanced by strong negative feedback from in-hibitory interneurons, a circuit element found in the hippocampus and the primary vi-sual cortex. In their working regime, ISNs produce damped oscillations in the γ-range in response to inputs to the inhibitory population. In order to understand the proper-ties of interconnected ISNs, we investigated periodic forcing of ISNs. We show that ISNs can be excited over a range of frequencies and derive properties of the resonance peaks. In particular, we studied the phase-locked solutions, the torus solutions and the resonance peaks. More particular, periodically forced ISNs respond with (possibly multi-stable) phase-locked activity whereas networks with sustained intrinsic oscilla-tions respond more dynamically to periodic inputs with tori. Hence, the dynamics are surprisingly rich and phase effects alone do not adequately describe the network re-sponse. This strengthens the importance of phase-amplitude coupling as opposed to phase-phase coupling in providing multiple frequencies for multiplexing and routing information. You can use \terry{text to print}essai
isnNC-RR.pdf (2.31 Mo) Télécharger le fichier
hal-01096590 , version 1 (17-12-2014)
hal-01096590 , version 2 (20-02-2015)
  • HAL Id : hal-01096590 , version 1
Romain Veltz, Terrence J. Sejnowski. Periodic forcing of stabilized E-I networks: Nonlinear resonance curves and dynamics. [Research Report] INRIA Sophia Antipolis. 2014. ⟨hal-01096590v1⟩
228 Consultations
406 Téléchargements
