Abstract : This paper discusses the visual-inertial structure from motion problem
(VI-SfM problem) with special focus on the following three fundamen-
tal issues: observability properties, resolvability in closed form and data
association. Regarding the rst issue, after a discussion about the cur-
rent state of the art, the paper rst investigates more complex scenarios.
Specically, with respect to the common formulation, which assumes
three orthogonal accelerometers and three orthogonal gyroscopes, the
analysis is extended to cope with the cases of a reduced number of
inertial sensors and any number of point features observed by monoc-
ular vision. In particular, the minimal case of a single accelerometer,
no gyroscope and a single point feature is addressed. Additionally, the
analysis accounts for biased measurements and unknown extrinsic cam-
era calibration. The results derived for these new and very challenging
scenarios have interesting consequences both from a technological and
neuroscientic perspective. Regarding the second issue, a simple closed
form solution to the VI-SfM is presented. This solution expresses the
structure of the scene and the motion only in terms of the visual and
in-ertial measurements collected during a short time interval. This allows
introducing deterministic algorithms able to simultaneously determine
the structure of the scene together with the motion without the need for
any initialization or prior knowledge. Additionally, the closed-form so-
lution allows us to identify the conditions under which the VI-SfM has
a nite number of solutions. Specically, it is shown that the prob-
lem can have a unique solution, two distinct solutions or innite so-
lutions depending on the trajectory, on the number of point-features
and on their arrangement in the 3D space and on the number of cam-
era images. Finally, the paper discusses the third issue, i.e., the data
association problem. Starting from basic results in computer vision, it
is shown that, by exploiting the information provided by the inertial
measurements, a single point correspondence (in the case of a planar
motion) and two point correspondences (for a general 3D motion) are
sucient to characterize the motion between two camera poses. This
allows us to use a 1-point RANSAC algorithm (in the planar case) or
a 2-point RANSAC algorithm (in the general 3D case) to detect out-
liers. The paper concludes with some discussion about connections to
related research elds both in the framework of computer science and
neuroscience.
