Index calculus in the trace zero variety - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Mathematics of Communications Année : 2015
We discuss how to apply Gaudry's index calculus algorithm for abelian varieties to solve the discrete logarithm problem in the trace zero variety of an elliptic curve. We treat in particular the practically relevant cases of field extensions of degree 3 or 5. Our theoretical analysis is compared to other algorithms present in the literature, and is complemented by results from a prototype implementation.
index-calc.pdf (346.45 Ko) Télécharger le fichier
hal-01097427 , version 1 (06-01-2015)
hal-01097427 , version 2 (26-12-2015)
Elisa Gorla, Maike Massierer. Index calculus in the trace zero variety. Advances in Mathematics of Communications, 2015, 9 (4), pp.515--539. ⟨10.3934/amc.2015.9.515⟩. ⟨hal-01097427v2⟩
117 Consultations
110 Téléchargements
