Dynamics of hot-potato routing in IP networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Renata Teixeira
  • Fonction : Auteur
  • PersonId : 962611
Aman Shaikh
  • Fonction : Auteur
  • PersonId : 962614
Tim Griffin
  • Fonction : Auteur
  • PersonId : 962615
Despite the architectural separation between intradomain and inter-domain routing in the Internet, intradomain protocols do influence the path-selection process in the Border Gateway Protocol (BGP). When choosing between multiple equally-good BGP routes, a router selects the one with the closest egress point, based on the intrado-main path cost. Under such hot-potato routing, an intradomain event can trigger BGP routing changes. To characterize the influ-ence of hot-potato routing, we conduct controlled experiments with a commercial router. Then, we propose a technique for associating BGP routing changes with events visible in the intradomain pro-tocol, and apply our algorithm to AT&T's backbone network. We show that (i) hot-potato routing can be a significant source of BGP updates, (ii) BGP updates can lag ¢ ¡ seconds or more behind the intradomain event, (iii) the number of BGP path changes triggered by hot-potato routing has a nearly uniform distribution across des-tination prefixes, and (iv) the fraction of BGP messages triggered by intradomain changes varies significantly across time and router locations. We show that hot-potato routing changes lead to longer delays in forwarding-plane convergence, shifts in the flow of traffic to neighboring domains, extra externally-visible BGP update mes-sages, and inaccuracies in Internet performance measurements.
p184-teixeira.pdf (387.3 Ko) Télécharger le fichier
hal-01097533 , version 1 (24-12-2014)
Renata Teixeira, Aman Shaikh, Tim Griffin, Jennifer Rexford. Dynamics of hot-potato routing in IP networks. ACM SIGMETRICS, Jun 2004, New York, United States. ⟨10.1145/1005686.1005723⟩. ⟨hal-01097533⟩
80 Consultations
452 Téléchargements
