Weighted Least Squares Based Detail Enhanced Exposure Fusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Scholarly Research Notices Année : 2014
Harbinder Singh
  • Fonction : Auteur correspondant
  • PersonId : 962663
Connectez-vous pour contacter l'auteur
Vinay Kumar
Many recent computational photography techniques play a significant role to avoid limitation of standard digital cameras to handle wide dynamic range of the real-world scenes, containing brightly and poorly illuminated areas. In many of these techniques, it is often desirable to fuse details from images captured at different exposure settings, while avoiding visual artifacts. In this paper we propose a novel technique for exposure fusion in which Weighted Least Squares (WLS) optimization framework is utilized for weight map refinement. Computationally simple texture features (i.e. detail layer extracted with the help of edge preserving filter) and color saturation measure are preferred for quickly generating weight maps to control the contribution from an input set of multi-exposure images. Instead of employing intermediate High Dynamic Range (HDR) reconstruction and tone mapping steps, well-exposed fused image is generated for displaying on conventional display devices. A further advantage of the present technique is that it is well suited for multi-focus image 2 fusion. Simulation results are compared with a number of existing single resolution and multi-resolution techniques to show the benefits of the proposed scheme for variety of cases.
Manuscript.pdf (5.91 Mo) Télécharger le fichier
498762.pdf (8.9 Mo) Télécharger le fichier
hal-01098118 , version 1 (22-05-2015)
Harbinder Singh, Vinay Kumar, Sunil Bhooshan. Weighted Least Squares Based Detail Enhanced Exposure Fusion. International Scholarly Research Notices, 2014, pp.18. ⟨10.1049/el:20020212⟩. ⟨hal-01098118⟩
76 Consultations
767 Téléchargements
