Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
1Mathematisches Institut [Bayreuth] (University of Bayreuth Faculty of Mathematics, Physics and Computer Science Mathematical Institute D-95440 Bayreuth Germany - Germany)
Abstract : The existence of a control Lyapunov function with the weak infinitesimal decrease via the Dini or the proximal subdifferential and the lower Hamiltonian characterizes asymp-totic controllability of nonlinear control systems and differential inclusions. We study the class of nonlinear differential inclusions with a right-hand side formed by the convex hull of active C 2 functions which are defined on subregions of the domain. For a simplicial triangulation we parametrize a control Lyapunov function (clf) for nonlinear control systems by a continuous, piecewise affine (CPA) function via its values at the nodes and demand a suitable negative upper bound in the weak decrease condition on all vertices of all simplices. Applying estimates of the proximal subdifferential via active gradients we can set up a mixed integer linear problem (MILP) with inequalities at the nodes of the triangulation which can be solved to obtain a CPA function. The computed function is a clf for the nonlinear control system. We compare this novel approach with the one applied to compute Lyapunov functions for strongly asymptotically stable differential inclusions and give a first numerical example.
https://hal.inria.fr/hal-01098270 Contributor : Estelle BouzatConnect in order to contact the contributor Submitted on : Tuesday, December 23, 2014 - 3:24:39 PM Last modification on : Friday, August 23, 2019 - 3:08:02 PM Long-term archiving on: : Tuesday, March 24, 2015 - 10:40:41 AM
Robert Baier, Sigurđur Freyr Hafstein. Numerical Computation of Control Lyapunov Functions in the Sense of Generalized Gradients. MTNS 2014, 2014, Groningen, Netherlands. pp.1173-1180. ⟨hal-01098270⟩
