Higher-Order Pushdown Trees are Circularly Computable - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We are interested in the problem of expressiveness of the following operations in the category of sets: finite products and coproducts, initial algebras (induction) and final coalgebras (coinduction). These operations are the building blocks of a logical system that allows circularity in Gentzen-style proofs. Proofs in this system are seen as simple programs, while the cut-elimination process is viewed as a running automaton with a memory device. In this paper, we show that higher-order trees, those accepted by higher-order pushdown automata, are computable in this setting, by providing an explicit simulation of the automata by cut-elimination.
jfla15_submission_8.pdf (337.42 Ko) Télécharger le fichier
hal-01099127 , version 1 (31-12-2014)
  • HAL Id : hal-01099127 , version 1
Jérôme Fortier. Higher-Order Pushdown Trees are Circularly Computable. Vingt-sixièmes Journées Francophones des Langages Applicatifs (JFLA 2015), Jan 2015, Le Val d'Ajol, France. ⟨hal-01099127⟩
75 Consultations
75 Téléchargements
