Abstract : Stochastic simulations involve multiple replications in order to build confidence
intervals for their results, and Designs Of Experiments (DOEs) to explore their parameters set. In
this paper, we propose Warp-Level Parallelism (WLP), a GPU-enabled solution to compute Multiple
Replications In Parallel (MRIP) on GPUs (Graphics Processing Units). GPUs are intrinsically
tuned to process efficiently the same operation on several data, which is not suited to parallelize
MRIP or DOEs. Our approach proposes to rely on small thread groups, called warps, to perform
independent computations such as replications. This approach has proved to be efficient on three
classical simulation models, but originally lacked the transparency users might expect. In this
work, we enhance WLP using Aspect Oriented Programming (AOP). Our work describes the way
to combine CUDA and AOP, and brings forward the techniques available to exploit AOP in a
CUDA-enabled development.
https://hal.inria.fr/hal-01099208
Contributor : Jonathan Passerat-Palmbach <>
Submitted on : Thursday, January 1, 2015 - 3:38:24 PM Last modification on : Monday, May 25, 2020 - 5:50:04 PM Long-term archiving on: : Thursday, September 10, 2015 - 11:57:11 PM
Jonathan Passerat-Palmbach, Pierre Schweitzer, Jonathan Caux, Pridi Siregar, Claude Mazel, et al.. Harnessing Aspect Oriented Programming on GPU: Application to Warp-Level Parallelism (WLP). International Journal of Computer Aided Engineering and Technology, Inderscience Publishers, 2015, 7 (2), pp.158-175. ⟨hal-01099208⟩
