A computationally effective dynamic hysteresis model taking into account skin effect in magnetic laminations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physica B+C Année : 2014
We propose a simplified dynamic hysteresis model for the prediction of magnetization behavior of electrical steel up to high frequencies, taking into account the skin effect. This model has the advantage of predicting the hysteresis loop and loss behavior versus frequency with the same accuracy provided by the Dynamic Preisach Model with a largely reduced computational burden. It is here compared to experimental results obtained in Fe-Si laminations under sinusoidal flux up to 2 kHz.
article.pdf (246.48 Ko) Télécharger le fichier
hal-01100311 , version 1 (08-01-2015)
Olivier de La Barrière, Carlo Ragusa, Carlo Appino, Fausto Fiorillo, Martino Lobue, et al.. A computationally effective dynamic hysteresis model taking into account skin effect in magnetic laminations. Physica B+C, 2014, 435, pp.80 - 83. ⟨10.1016/j.physb.2013.09.036⟩. ⟨hal-01100311⟩
373 Consultations
252 Téléchargements
