High-frequency rotational losses in different Soft Magnetic Composites (SMC) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Physics Année : 2014
The isotropic properties of Soft Magnetic Composites (SMC) favor the design of new machine topologies and their granular structure can induce a potential decrease of the dynamic loss component at high frequencies. This paper is devoted to the characterization of the broadband magnetic losses of different SMC types under alternating and circular induction. The investigated materials differ by their grain size, heat treatment, compaction rate and binder type. It is shown that, up to peak polarization Jp = 1.25 T, the ratios between the rotational and the alternating loss components (classical, hysteresis, and excess) are quite independent of the material structural details, quite analogous to the known behavior of nonoriented steel laminations. At higher inductions, however, this is no more the case. It is observed, in particular, that the Jp value at which the rotational hysteresis loss attains its maximum, related to the progressive disappearance of the domain walls under increasing rotational fields, decreases with the material susceptibility.
article.pdf (102.42 Ko) Télécharger le fichier
hal-01100338 , version 1 (06-01-2015)
  • HAL Id : hal-01100338 , version 1
Olivier de La Barrière, C Appino, C Ragusa, F Fiorillo, F Mazaleyrat, et al.. High-frequency rotational losses in different Soft Magnetic Composites (SMC). Journal of Applied Physics, 2014, pp.17A331-1-17A331-3. ⟨hal-01100338⟩
216 Consultations
156 Téléchargements
