Computation of Lyapunov Functions for Discrete-Time Systems using the Yoshizawa Construction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a new approach for com-puting Lyapunov functions for nonlinear discrete-time systems with an asymptotically stable equilibrium at the origin. The pro-posed method constructs a continuous piecewise affine (CPA) function on a compact subset of the state space containing the origin, given a suitable triangulation or partition of the compact set and values at the vertices of the triangulation. Here, the vertex values are fixed using a function from a classical con-verse Lyapunov theorem originally due to Yoshizawa. Several numerical examples are presented to illustrate the proposed approach.
Li_etal_Yoshizawa_discrete_2014.pdf (520.06 Ko) Télécharger le fichier
hal-01101289 , version 1 (06-03-2015)
  • HAL Id : hal-01101289 , version 1
Huijuan Li, Sigurður Hafstein, Christopher M. Kellett. Computation of Lyapunov Functions for Discrete-Time Systems using the Yoshizawa Construction. CDC 2014, Dec 2014, Los Angeles, United States. ⟨hal-01101289⟩
Collections
SADCO TDS-MACS
42 Consultations
157 Téléchargements
