Cut-elimination and the decidability of reachability in alternating pushdown systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We propose a new approach to formalize alternating pushdown systems as natural-deduction style inference systems. In this approach, the decidability of reachability can be proved as a simple consequence of a cut-elimination theorem for the corresponding inference system. Then, we show how this result can be used to extend an alternating pushdown system into a complete system where, for every configuration $A$, either $A$ or $\neg A$ is provable. The key idea is that cut-elimination permits to build a system where a proposition of the form $\neg A$ has a co-inductive (hence possibly infinite) proof if and only if it has an inductive (hence finite) proof.
reachability.pdf (183.08 Ko) Télécharger le fichier
hal-01101835 , version 1 (30-01-2015)
Paternité - Partage selon les Conditions Initiales
  • HAL Id : hal-01101835 , version 1
Gilles Dowek, Ying Jiang. Cut-elimination and the decidability of reachability in alternating pushdown systems. 2015. ⟨hal-01101835⟩
Collections
INRIA INRIA2
96 Consultations
43 Téléchargements
