Triple Handshakes and Cookie Cutters: Breaking and Fixing Authentication over TLS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
TLS was designed as a transparent channel abstraction to allow developers with no cryptographic expertise to protect their application against attackers that may control some clients, some servers, and may have the capability to tamper with network connections. However, the security guarantees of TLS fall short of those of a secure channel, leading to a variety of attacks. We show how some widespread false beliefs about these guarantees can be exploited to attack popular applications and defeat several standard authentication methods that rely too naively on TLS. We present new client impersonation attacks against TLS renegotiations, wireless networks, challenge-response protocols, and channel-bound cookies. Our attacks exploit combinations of RSA and Diffie-Hellman key exchange, session resumption, and renegotiation to bypass many recent countermeasures. We also demonstrate new ways to exploit known weaknesses of HTTP over TLS. We investigate the root causes for these attacks and propose new countermeasures. At the protocol level, we design and implement two new TLS extensions that strengthen the authentication guarantees of the handshake. At the application level, we develop an exemplary HTTPS client library that implements several mitigations, on top of a previously verified TLS implementation, and verify that their composition provides strong, simple application security.
triple-handshakes-and-cookie-cutters-oakland14.pdf (646.71 Ko) Télécharger le fichier
hal-01102259 , version 1 (04-04-2016)
Karthikeyan Bhargavan, Antoine Delignat-Lavaud, Cédric Fournet, Alfredo Pironti, Pierre-Yves Strub. Triple Handshakes and Cookie Cutters: Breaking and Fixing Authentication over TLS. IEEE Symposium on Security & Privacy, Apr 2014, San Jose, United States. ⟨10.1109/SP.2014.14⟩. ⟨hal-01102259⟩
Collections
INRIA INRIA2
241 Consultations
1797 Téléchargements
