Ballot secrecy with malicious bulletin boards - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
This letter proposes a formal definition of ballot secrecy in the computational model of cryptography. The definition builds upon and strengthens earlier definitions by Bernhard et al. (ASIACRYPT'12, ESORICS'11 & ESORICS'13). The new definition is intended to ensure that ballot secrecy is preserved in the presence of malicious bulletin boards, whereas earlier definitions by Bernhard et al. only consider honest bulletin boards.
Fichier non déposé
hal-01102306 , version 1 (12-01-2015)
  • HAL Id : hal-01102306 , version 1
Ben Smyth, David Bernhard. Ballot secrecy with malicious bulletin boards. [Research Report] 2014/822, Cryptology ePrint Archive. 2014, pp.7. ⟨hal-01102306⟩
Collections
INRIA INRIA2 LARA
87 Consultations
0 Téléchargements
