Architectural Support for Software-Defined Metadata Processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hardware for propagating and checking software-programmable metadata tags can achieve low runtime overhead when carefully implemented. We generalize prior work on hardware tagging by considering a generic architecture that supports software-defined policies over metadata of arbitrary size and complexity; we introduce several novel microarchitectural optimizations that keep the overhead of this rich processing low. Our model thus achieves the efficiency of previous hardware-based approaches with the flexibility of the software-based ones. We demonstrate this by using it to enforce four diverse safety and security policies---spatial and temporal memory safety, taint tracking, control-flow integrity, and code and data separation---plus a composite policy that enforces all of them simultaneously. Experiments on SPEC CPU2006 benchmarks show modest impact on runtime (typically under 10%) and power ceiling (less than 10%), in return for some increase in energy usage (typically under 60%) and area for on-chip memory structures (110%).
hal-01102378 , version 1 (12-01-2015)
Udit Dhawan, Cătălin Hriţcu, Rafi Rubin, Nikos Vasilakis, Silviu Chiricescu, et al.. Architectural Support for Software-Defined Metadata Processing. 20th International Conference on Architectural Support for Programming Languages and Operating Systems (ASPLOS 2015), Mar 2015, Istanbul, Turkey. pp.487-502, ⟨10.1145/2694344.2694383⟩. ⟨hal-01102378⟩
Collections
INRIA INRIA2
89 Consultations
0 Téléchargements
