Statistical Inference for Partial Differential Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Many physical phenomena are modeled by parametrized PDEs. The poor knowledge on the involved parameters is often one of the numerous sources of uncertainties on these models. Some of these parameters can be estimated, with the use of real world data. The aim of this mini-symposium is to introduce some of the various tools from both statistical and numerical communities to deal with this issue. Parametric and non-parametric approaches are developed in this paper. Some of the estimation procedures require many evaluations of the initial model. Some interpolation tools and some greedy algorithms for model reduction are therefore also presented, in order to reduce time needed for running the model.
proc144518.pdf (625.78 Ko) Télécharger le fichier
hal-01102782 , version 1 (13-01-2015)
Emmanuel Grenier, Marc Hoffmann, Tony Lelièvre, Violaine Louvet, Clémentine Prieur, et al.. Statistical Inference for Partial Differential Equations. SMAI 2013 - 6e Biennale Française des Mathématiques Appliquées et Industrielles, May 2013, Seignosse, France. pp.178-188, ⟨10.1051/proc/201445018⟩. ⟨hal-01102782⟩
784 Consultations
1834 Téléchargements
