Facing the Challenge of Nondeterminism in MPSoC Debugging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
This paper investigates the application of Deterministic Record Replay (DRR) to the problem of software debugging on modern nondeterministic MPSoC architectures. It presents a taxonomy of existing approaches and reports on our experience in implementing a DRR-based debugger. Identifying MPSoC specific debugging needs, the ReDSoC prototype defines a general debugging methodology to focus and zoom on problematic zones. Its successful application in the case of multimedia applications running on real platforms puts forward the importance of DRR for MPSoC debugging while pinpointing the major reasons hindering its larger use.
hal.pdf (2.59 Mo) Télécharger le fichier
hal-01103620 , version 1 (15-01-2015)
  • HAL Id : hal-01103620 , version 1
Kiril Georgiev, Vania Marangozova-Martin. Facing the Challenge of Nondeterminism in MPSoC Debugging. 2015. ⟨hal-01103620⟩
122 Consultations
185 Téléchargements
