Assessing the robustness of parsimonious predictions for gene neighborhoods from reconciled phylogenies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The availability of a large number of assembled genomes opens the way to study the evolution of syntenic character within a phylogenetic context. The DeCo algorithm, recently introduced by Bérard et al. allows the computation of parsimonious evolutionary scenarios for gene adjacencies, from pairs of reconciled gene trees. Following the approach pioneered by Sturmfels and Pachter, we describe how to modify the DeCo dynamic programming algorithm to identify classes of cost schemes that generates similar parsimonious evolutionary scenarios for gene adjacencies, as well as the robustness to changes to the cost scheme of evolutionary events of the presence or absence of specific ancestral gene adjacencies. We apply our method to six thousands mammalian gene families, and show that computing the robustness to changes to cost schemes provides new and interesting insights on the evolution of gene adjacencies and the DeCo model.
DeClope_isbra.pdf (357.16 Ko) Télécharger le fichier
hal-01104587 , version 1 (18-01-2015)
hal-01104587 , version 2 (17-03-2015)
hal-01104587 , version 3 (19-03-2015)
Paternité
Ashok Rajaraman, Cedric Chauve, Yann Ponty. Assessing the robustness of parsimonious predictions for gene neighborhoods from reconciled phylogenies. ISBRA - 11th International Symposium on Bioinformatics Research and Applications - 2015, Jun 2015, Norfolk, Virginia, United States. ⟨hal-01104587v2⟩
1165 Consultations
864 Téléchargements
