Real-time FEM based control of soft surgical robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a new method for the control of soft surgical robots based on the real-time inverse simulation with internal deformation computed through the use of Finite Element Method. We also consider the coupling of this method with a modified version of the same algorithm for parametrization of soft-tissue models, in order to control the navigation of the robot while gathering information on the surrounding organs.
2014-42-Frederick_Largilliere_LIFL.pdf (1.47 Mo) Télécharger le fichier
hal-01105146 , version 1 (19-01-2015)
  • HAL Id : hal-01105146 , version 1
Frederick Largilliere, Eulalie Coevoet, Laurent Grisoni, Christian Duriez. Real-time FEM based control of soft surgical robots. SURGETICA 2014, Dec 2014, Chambéry, France. ⟨hal-01105146⟩
326 Consultations
279 Téléchargements
