New interface
Conference papers
New Pareto approach for ranking triangular fuzzy numbers
Abstract : Ranking fuzzy numbers is an important aspect in dealing with fuzzy optimization problems in many areas. Although so far, many fuzzy ranking methods have been discussed. This paper proposes a new Pareto approach over triangular fuzzy numbers. The approach is composed of two dominance stages. In the first stage, mono-objective dominance relations are introduced and tested with some examples. In the second stage, a Pareto dominance is defined for multi-objective optimization and then applied to solve a vehicle routing problem (VRP).
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01107761
Contributor : TALBI El-Ghazali Connect in order to contact the contributor
Submitted on : Wednesday, January 21, 2015 - 3:09:41 PM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
Identifiers
Citation
Oumayma Bahri, Nahla Ben Amor, El-Ghazali Talbi. New Pareto approach for ranking triangular fuzzy numbers. IPMU 2014 : 15th International Conference nformation Processing and Management of Uncertainty in Knowledge-Based Systems, Jul 2014, Montpellier, France. pp.264-273, ⟨10.1007/978-3-319-08855-6_27⟩. ⟨hal-01107761⟩
Share
Metrics
Record views
115
