New Pareto approach for ranking triangular fuzzy numbers
Ranking fuzzy numbers is an important aspect in dealing with fuzzy optimization problems in many areas. Although so far, many fuzzy ranking methods have been discussed. This paper proposes a new Pareto approach over triangular fuzzy numbers. The approach is composed of two dominance stages. In the first stage, mono-objective dominance relations are introduced and tested with some examples. In the second stage, a Pareto dominance is defined for multi-objective optimization and then applied to solve a vehicle routing problem (VRP).
