Interval Observer Design for Estimation and Control of Time-Delay Descriptor Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Control Année : 2015
The problem of interval observer design is addressed for a class of descriptor linear systems with time delays. First, an interval observation for any input in the system is provided. Second, the control input is designed together with the observer gains in order to guarantee interval estimation and stabilization simultaneously. Efficiency of the proposed approach is illustrated by numerical experiments with Leontief delayed model.
Interval_Descriptor_J.pdf (340.89 Ko) Télécharger le fichier
hal-01108432 , version 1 (22-01-2015)
Denis Efimov, Andrey Polyakov, Jean-Pierre Richard. Interval Observer Design for Estimation and Control of Time-Delay Descriptor Systems. European Journal of Control, 2015, 23 (5), pp.26-35. ⟨10.1016/j.ejcon.2015.01.004⟩. ⟨hal-01108432⟩
352 Consultations
703 Téléchargements
