Conditional Quantile Estimation based on Optimal Quantization: from Theory to Practice - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Statistics and Data Analysis Année : 2015
Small-sample properties of a nonparametric estimator of conditional quantiles based on optimal quantization, that was recently introduced (J. Statist. Plann. Inference, 156, 14–30, 2015), are investigated. More precisely, (i) the practical implementation of this estimator is discussed (by proposing in particular a method to properly select the corresponding smoothing parameter, namely the number of quantizers) and (ii) its finite- sample performances are compared to those of classical competitors. Monte Carlo studies reveal that the quantization-based estimator competes well in all cases and sometimes dominates its competitors, particularly when the regression function is quite complex. A real data set is also treated. While the main focus is on the case of a univariate covariate, simulations are also conducted in the bivariate case.
CPS15b.pdf (5.91 Mo) Télécharger le fichier
hal-01108504 , version 1 (22-01-2015)
hal-01108504 , version 2 (13-01-2016)
  • HAL Id : hal-01108504 , version 2
Isabelle Charlier, Davy Paindaveine, Jérôme Saracco. Conditional Quantile Estimation based on Optimal Quantization: from Theory to Practice. Computational Statistics and Data Analysis, 2015. ⟨hal-01108504v2⟩
211 Consultations
188 Téléchargements
