The lexicographic degree of the first two-bridge knots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
We study the degree of polynomial representations of knots. We give here the lexicographic degree of all knots with eight or fewer crossings. The proof uses the braid theoretical method developed by Orevkov to study real plane curves, isotopies on trigonal curves and explicit parametrizations obtained by perturbing a triple point.
bkp14-3.pdf (302.76 Ko) Télécharger le fichier
hal-01108678 , version 1 (23-01-2015)
hal-01108678 , version 2 (11-09-2018)
Erwan Brugallé, Pierre-Vincent Koseleff, Daniel Pecker. The lexicographic degree of the first two-bridge knots: Extended abstract. 2014. ⟨hal-01108678v1⟩
514 Consultations
431 Téléchargements
