Covering spaces and Delaunay triangulations of the 2D flat torus
A previous algorithm was computing the Delaunay triangulation of the flat torus, by using a 9-sheeted covering space. We propose a modification of the algorithm using only a 8-sheeted covering space, which allows to work with 8 periodic copies of the input points instead of 9. The main interest of our contribution is not only this result, but most of all the method itself: this new construction of covering spaces generalizes to Delaunay triangulations of surfaces of higher genus.
Format : Figure, Image
