Covering spaces and Delaunay triangulations of the 2D flat torus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A previous algorithm was computing the Delaunay triangulation of the flat torus, by using a 9-sheeted covering space. We propose a modification of the algorithm using only a 8-sheeted covering space, which allows to work with 8 periodic copies of the input points instead of 9. The main interest of our contribution is not only this result, but most of all the method itself: this new construction of covering spaces generalizes to Delaunay triangulations of surfaces of higher genus.
hal.pdf (309.21 Ko) Télécharger le fichier
Format : Figure, Image
hal-01109626 , version 1 (26-01-2015)
  • HAL Id : hal-01109626 , version 1
Mikhail Bogdanov, Monique Teillaud, Gert Vegter. Covering spaces and Delaunay triangulations of the 2D flat torus. 28th European Workshop on Computational Geometry, Mar 2012, Assisi, Italy. ⟨hal-01109626⟩
Collections
INRIA INRIA2
261 Consultations
207 Téléchargements
