Dynamic Programming Based Metaheuristic for the Unit Commitment Problem
Unit Commitment Problem (UCP) is a strategic optimization problem in power system operation. Its objective is to schedule the generating units online or offline over a scheduling horizon such that the power production cost is minimized with the load demand fully met and the operation constraints satisfied.In this paper an approach to solve the UCP called DYNAMOP for DYNAmic programming using Metaheuristic for Optimizations Problems is proposed. The main idea of this method is to use a genetic algorithm (GA) to run through the graph of Dynamic Programming.
