The TTC 2014 Movie Database Case: Rascal Solution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rascal is a meta-programming language for processing source code in the broad sense (models, doc-uments, formats, languages, etc.). In this short note we discuss the implementation of the "TTC'14 Movie Database Case" in Rascal. In particular we will highlight the challenges and benefits of using a functional programming language for transforming graph-based models.
Autre [cs.OH]
inostroza.pdf (115.19 Ko) Télécharger le fichier
hal-01110851 , version 1 (29-01-2015)
  • HAL Id : hal-01110851 , version 1
Pablo Inostroza, Tijs van Der Storm. The TTC 2014 Movie Database Case: Rascal Solution . Transformation Tool Contest, 2014, L'Aquila, Italy. pp.155 - 159. ⟨hal-01110851⟩
Collections
INRIA INRIA2
226 Consultations
106 Téléchargements
