Evolving Languages with Object Algebras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
—Object Algebras are a programming technique for the extensible implementation of recursive data types. This extended abstract introduces Object Algebras and shows how they could be used to develop highly evolvable software languages. The paper is concluded with a discussin of directions for further research.
Autre [cs.OH]
23132A.pdf (79.36 Ko) Télécharger le fichier
hal-01110869 , version 1 (29-01-2015)
  • HAL Id : hal-01110869 , version 1
Pablo Inostroza, Tijs van Der Storm. Evolving Languages with Object Algebras. BENEVOL 2014 - Proceedings of the Belgian-Netherlands Evoluation Workshop, 2014, Amsterdam, Netherlands. pp.2. ⟨hal-01110869⟩
Collections
INRIA INRIA2
46 Consultations
52 Téléchargements
