Certified Abstract Interpretation with Pretty-Big-Step Semantics
This paper describes an investigation into developing certified abstract
interpreters from big-step semantics using the Coq proof assistant.
We base our approach on Schmidt’s abstract interpretation
principles for natural semantics, and use a pretty-big-step (PBS) semantics,
a semantic format proposed by Charguéraud. We propose
a systematic representation of the PBS format and implement it in
Coq. We then show how the semantic rules can be abstracted in a
methodical fashion, independently of the chosen abstract domain,
to produce a set of abstract inference rules that specify an abstract
interpreter. We prove the correctness of the abstract interpreter in
Coq once and for all, under the assumption that abstract operations
faithfully respect the concrete ones. We finally show how to define
correct-by-construction analyses: their correction amounts to proving
they belong to the abstract semantics.
BodinJensenSchmitt-CPP 2015-Certified Abstract Interpretation with Pretty-Big-Step Semantics-rpx.pdf (455.09 Ko)
Télécharger le fichier
