Accelerated ageing and lifetime prediction of poly(3-hydroxybutyrate-co-3-hydroxyvalerate) in distilled water - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Polymer Testing Année : 2014
Accelerated ageing was performed in distilled water at different temperatures (25, 30, 40 and 50°C) on poly(3-hydroxybutyrate-co-3-hydroxyvalerate) (PHBV), which is a biodegradable biopolymer, in order to estimate its lifetime in aqueous environment. In a first part, degradation mechanisms were followed by gravimetry, tensile tests and steric exclusion chromatography. Both immersion and relative humidity have been examined. In a second part, the strain at break was used as an indicator for lifetime prediction with an Arrhenius extrapolation. The study revealed the presence of only one irreversible degradation mechanism, i.e. hydrolytic degradation, which is temperature dependant. So, within the approach assumptions, the lifetime in distilled water of PHBV following Arrhenius behaviour can be predicted.
Deroine2014.pdf (546.65 Ko) Télécharger le fichier
hal-01113114 , version 1 (19-09-2018)
Morgan Deroiné, Antoine Le Duigou, Yves-Marie Corre, Pierre Yves Le Gac, Peter Davies, et al.. Accelerated ageing and lifetime prediction of poly(3-hydroxybutyrate-co-3-hydroxyvalerate) in distilled water. Polymer Testing, 2014, 39, pp.70-78. ⟨10.1016/j.polymertesting.2014.07.018⟩. ⟨hal-01113114⟩
220 Consultations
296 Téléchargements
