Cells Detection Using Segmentation Competition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Emmanuel Soubies
Xavier Descombes
In this paper we address the problem of cells detection from mi-croscopy images. We construct a dictionary of candidate shapes obtained from previous segmentation maps and define an energy function to select the best candidates. The energy minimization is performed by an iterative graph cut algorithm. The proposed approach optimally combines the segmentation maps obtained with different methods and/or parameters. We show on synthetic and real data that this process allows to drastically improve the performance of each individual segmentation.
Poulain_ISBI15.pdf (428.52 Ko) Télécharger le fichier
hal-01113167 , version 1 (04-02-2015)
Emmanuelle Poulain, Sylvain Prigent, Emmanuel Soubies, Xavier Descombes. Cells Detection Using Segmentation Competition. ISBI - International Symposium on Biomedical Imaging, Apr 2015, Brooklyn, United States. ⟨10.1109/ISBI.2015.7164090⟩. ⟨hal-01113167⟩
356 Consultations
262 Téléchargements
