Numerical analysis of a robust entropy-diminishing Finite Volume scheme for parabolic equations with gradient structure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We present a numerical method for approximating the solutions of degenerate parabolic equations with a formal gradient flow structure. The numerical method we propose preserves the formal gradient flow structure at the discrete level. The existence of a solution to and the convergence of the scheme are proved under very general assumptions on the continuous problem (nonlinearities, anisotropy, heterogeneity) and on the mesh. We also provide numerical evidences of the efficiency and of the robustness of our approach.
VAGNL-preprint.pdf (677.18 Ko) Télécharger le fichier
hal-01119735 , version 1 (24-02-2015)
hal-01119735 , version 2 (18-03-2015)
hal-01119735 , version 3 (10-02-2016)
hal-01119735 , version 4 (07-07-2016)
Clément Cancès, Cindy Guichard. Numerical analysis of a robust entropy-diminishing Finite Volume scheme for parabolic equations with gradient structure. 2015. ⟨hal-01119735v2⟩
710 Consultations
638 Téléchargements
