HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Relative group sparsity for non-negative matrix factorization with application to on-the-fly audio source separation
Abstract : We consider dictionary-based signal decompositions with group sparsity, a variant of structured sparsity. We point out that the group sparsity-inducing constraint alone may not be sufficient in some cases when we know that some bigger groups or so-called supergroups cannot vanish completely. To deal with this problem we introduce the notion of relative group sparsity preventing the supergroups from vanishing. In this paper we formulate practical criteria and algorithms for relative group sparsity as applied to non-negative matrix factorization and investigate its potential benefit within the on-the-fly audio source separation framework we recently introduced. Experimental evaluation shows that the proposed relative group sparsity leads to performance improvement over group sparsity in both supervised and semi-supervised on-the-fly audio source separation settings.
Document type :
Conference papers
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01120009
Contributor : Alexey Ozerov Connect in order to contact the contributor
Submitted on : Wednesday, December 30, 2015 - 1:43:25 PM
Last modification on : Monday, January 4, 2016 - 2:42:08 PM
Long-term archiving on: : Tuesday, April 5, 2016 - 1:45:01 PM
File
paper.pdf
Identifiers
  • HAL Id : hal-01120009, version 2
Citation
Dalia El Badawy, Alexey Ozerov, Ngoc Q. K. Duong. Relative group sparsity for non-negative matrix factorization with application to on-the-fly audio source separation . Proc. of the IEEE International Conference on Acoustics, Speech, and Signal Processing (ICASSP'15), Apr 2015, Brisbane, Australia. ⟨hal-01120009v2⟩
Share
Metrics
Record views
73
Files downloads
321
