A Chemistry-inspired Programming Model for Adaptive Decentralised Workflows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
In this paper, we devise a chemistry-inspired programming model for the decentralised execution of scientific workflows, with the possibility of dynamically adapting its shape when its initial specification fails to reach the user's requirements or simply to run due to external conditions. We describe a decentralised architecture to support the model and cover its implementation in the GinFlow software prototype.
RR-8691.pdf (1.53 Mo) Télécharger le fichier
hal-01120274 , version 1 (09-03-2015)
  • HAL Id : hal-01120274 , version 1
Javier Rojas Balderrama, Matthieu Simonin, Cédric Tedeschi. A Chemistry-inspired Programming Model for Adaptive Decentralised Workflows. [Research Report] RR-8691, INRIA. 2015. ⟨hal-01120274⟩
352 Consultations
119 Téléchargements
