Toward a Net Neutrality Debate that Conforms to the 2010s
Network neutrality has been topic of discussion for the past 25 years. In this position paper, we aim at highlighting that the issue is somewhat bypassed with the use of often forgotten actors such as Content Delivery Network (CDN) providers. Our goal is then to ignite a discussion on whether an extension of the debate is required. We particularly start to extend the usually discussed neutrality definitions, in order to keep them relevant in an increasingly complexifying Internet ecosystem.
Recherche opérationnelle [math.OC]
