Privacy-Preserving Reputation Mechanism: A Usable Solution Handling Negative Ratings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Reputation mechanisms allow users to mutually evaluate their trust. This is achieved through the computation of a reputation score summarizing their past behaviors. Depending on these scores, users are free to accept or refuse to interact with each other. When users are virtual, volatile, or distant, an accurate evaluation of reputation scores is complex. Furthermore, users expect reputation mechanisms to preserve the privacy of their interactions and of their feedback. Existing solutions often rely on costly cryptographic tools that may lead to impractical solutions. In this article, we propose a usable privacy preserving reputation mechanism. This mechanism is distributed and handles non-monotonic ratings. Its implementation on cheap single board computers validates its adequacy to large-scale systems.
report_simu.pdf (533.71 Ko) Télécharger le fichier
hal-01131975 , version 1 (16-03-2015)
hal-01131975 , version 2 (17-03-2015)
Paul Lajoie-Mazenc, Emmanuelle Anceaume, Gilles Guette, Thomas Sirvent, Valérie Viet Triem Tong. Privacy-Preserving Reputation Mechanism: A Usable Solution Handling Negative Ratings. 9th IFIP WG 11.11 International Conference, IFIPTM 2015, May 2015, Hambourg, Germany. pp.92-108, ⟨10.1007/978-3-319-18491-3_7⟩. ⟨hal-01131975v2⟩
744 Consultations
450 Téléchargements
