Dynamic Network Coding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2015
This document presents a network coding approach that allows coding decisions to be based on the instantaneous conditions at the network nodes. It uses dynamic rates and coefficients to constantly adapt to local conditions and to allow for provider and application differentiation.
draft-montpetit-dynamic-nc-00.pdf (40.95 Ko) Télécharger le fichier
hal-01132183 , version 1 (16-03-2015)
  • HAL Id : hal-01132183 , version 1
Marie-Jose Montpetit, Vincent Roca, Jonathan Detchart. Dynamic Network Coding. 2015. ⟨hal-01132183⟩
125 Consultations
153 Téléchargements
