Controllability of spin-boson systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Physics Année : 2015
In this paper we study the so-called spin-boson system, namely {a two-level system} in interaction with a distinguished mode of a quantized bosonic field. We give a brief description of the controlled Rabi and Jaynes--Cummings models and we discuss their appearance in the mathematics and physics literature. We then study the controllability of the Rabi model when the control is an external field acting on the bosonic part. Applying geometric control techniques to the Galerkin approximation and using perturbation theory to guarantee non-resonance of the spectrum of the drift operator, we prove approximate controllability of the system, for almost every value of the interaction parameter.
rabi2013_2015_hal.pdf (517.81 Ko) Télécharger le fichier
hal-01132741 , version 1 (18-03-2015)
Ugo Boscain, Paolo Mason, Gianluca Panati, Mario Sigalotti. Controllability of spin-boson systems. Journal of Mathematical Physics, 2015, 56. ⟨hal-01132741⟩
538 Consultations
197 Téléchargements
