Refinement to Certify Abstract Interpretations, Illustrated on Linearization for Polyhedra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
Sylvain Boulmé
Alexandre Maréchal
  • Fonction : Auteur
Our concern is the modular development of a certified static analyzer in Coq: we extend a certified abstract domain of convex poly-hedra with a linearization procedure approximating polynomial expressions. In order to help such a development, we propose a proof framework, embedded in Coq, that implements a refinement calculus. It allows to hide for proofs several low-level aspects of the computations on abstract domains. Moreover, refinement proofs are naturally simplified thanks to computations of weakest preconditions.
refinement_for_ai.pdf (538.2 Ko) Télécharger le fichier
hal-01133865 , version 1 (20-03-2015)
hal-01133865 , version 2 (15-07-2015)
hal-01133865 , version 3 (12-12-2017)
hal-01133865 , version 4 (15-11-2018)
  • HAL Id : hal-01133865 , version 2
Sylvain Boulmé, Alexandre Maréchal. Refinement to Certify Abstract Interpretations, Illustrated on Linearization for Polyhedra. 2015. ⟨hal-01133865v2⟩
428 Consultations
329 Téléchargements
